waz
I've been taking a part my 09 Phazer to get ready for the season and took a part my air box and found there is a lot of oil inside. The sled is new to me and pretty sure there shouldn't be oil in the air filter?
Also in the second picture notice the oil coming out of the cylinder? is this a problem to look out for?
Also I failed to notice when I took it a part, does the Idle adjusting screw go any place in particular or does it just dangle?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Been on its side.
Super Sled
- Feb 25, 2009
- Summit X
APEX 06 said:Been on its side.
Yep, you could have over filled the oil tank, or more probably you had it flipped over too much on its side.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Oil accumulates in the air box if the sled was on its side or the oil was over filled. A roll over valve would fix this.
Some dish soap to cut the grease and a good wash of the filter and you should be good to go.
I can't really see where the oil is coming out from?
The idle adjustment goes on the frame. I have mine apart so I snapped a photo for ya...
waz
Thanks for the replys, tipping over the sled seems like what it would be, have had it on it's side twice now going to wash it out and clean thanks.
Ahh missing the idle holder since I have the front end off the sled right now, thanks for the pic!
- Nov 1, 2009
- 2009 Phazer RTX
waz said:Thanks for the replys, tipping over the sled seems like what it would be, have had it on it's side twice now going to wash it out and clean thanks.
If tipping it on its side happens a lot I would invest in a roll over valve. Shuts the sled off and closes the breather tube that the oil leaks out of anf into the air box.
BombaPolaYama
It still happens without tipping over so I guess a rollover valve wouldn't fix that - could be over filled I guess. Basically everytime I have looked in my airbox there has been some oil in there and I have only ever had it on the side once. Possible to reroute the tube to the outside of the box -anyone done it?yamahas said:waz said:Thanks for the replys, tipping over the sled seems like what it would be, have had it on it's side twice now going to wash it out and clean thanks.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Holy crap that's one dirty girl!!
- Nov 1, 2009
- 2009 Phazer RTX
BombaPolaYama said:It still happens without tipping over so I guess a rollover valve wouldn't fix that - could be over filled I guess. Basically everytime I have looked in my airbox there has been some oil in there and I have only ever had it on the side once. Possible to reroute the tube to the outside of the box -anyone done it?yamahas said:waz said:Thanks for the replys, tipping over the sled seems like what it would be, have had it on it's side twice now going to wash it out and clean thanks.
Right, even if I don't tip over an oil residue will make it way to the air box. Just saying if he has it on the side often a roll over valve would be a good investment. The usual residue is not a problem, if you have oil pooling in the air box that is not normal.
canoehead
- Jan 14, 2011
- NE, Alberta
You might want to check your oil level!
waz
I tipped it on it's side twice since I've got it, hopefully not a common occurrence, going to clean the air filter and the box and clean up all the oil.
She's dirty cause she looks like this right now, oil is pretty low after taking the front end off and changing the filter... Just waiting for the bushing kits...
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
overfilled
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
digging up an old one here but I get crappy looking oil in the airbox, all the time, even without any sidehilling.
Whats the correct oil level procedure? (dipstick screwed in or not)
Thanks.
Thanks.
71rdrnr
- Oct 12, 2009
- Winnipeg MB. Canada
- 2010 phazer RTX
I believe not screwed in... Somebody???
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
Not screwed in.
- 6K
