samrx1
i start my engine and warm up .. a few minutes .. then . i stop .. and check for leak .. prestone ..and oil ..
and i see in intake of turbo .. have . oil..
and the exit of down pipe .. ..many oil ???
also i check . oil return.. its ok
what do you think guys..
it is a new turbo ..
sam
sam
pdrmike
- Dec 13, 2005
- Berlin, WI / Ontonagon,MI
- 12 APEX'S 09 Venture GT
Do you have the oil line going into the Turbo regulated with a pilot jet? I have a 35 pilot in mine.
samrx1
oups ..... no i dont have ...
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Mine did exact same thing... and did not knew the restriction requirement at that time...
Eated a full pint of oil each ride.... and was smoky!
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
samrx1 said:i start my engine and warm up .. a few minutes .. then . i stop .. and check for leak .. prestone ..and oil ..
sam
The Garrett GT2860RS requires an 0.035 restrictor on the oil inlet.
I stock them in -3 and -4 AN fittings.
-3 http://turboaddictionparts.com/catalog/ ... cts_id=291
-4 http://turboaddictionparts.com/catalog/ ... ucts_id=82
Ted.
samrx1
thank ..mike and ted ..
i go to double check my return line if it plug or bend ..
i come back after .
i phone .. dave at powder lite . the turbo come from there ..
and he recommend me to check this before..
thank you again guys.
sam.
i come back after .
sam.
samrx1
Need for Speed 2
You got her now buddy
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
I called Dave at PL about this and he told me that when running his GT2860RS and his oil kit a restrictor was not necessary.
Parts were bought in November 2008. He may have changed the design of the oil feed line and turbo lately so a restrictor is not needed anymore, I'm guessing here.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
rxrider said:I called Dave at PL about this and he told me that when running his GT2860RS and his oil kit a restrictor was not necessary.
Garrett says otherwise.
0.035 for Ball bearing
0.060 for non ball bearing.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Not good.... not at this time trying to finish off the sled... I'll run it and will probably be back with an order for the restrictors when she starts smoking :-(
