TRUE BLUE SINCE 1980
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
I have a friend has a rtx le. He has 500 or so miles on it . The oil light is blinking and throwing it on the rev limiter. Oil level is ok and he had it to a dealer and they could not replicate the problem. Going riding with him Saturday . Any one have this issue or have a clue to a fix . He has had it in a heated garage for the last few days, thinking it may be a moisture issue.
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
Ok, I rode this sled and it definitely has something going on with it. When it is in its "problem state", when you crack the throttle to w/o the oil light comes on and the motor stumbles.... It did it 7/8 times in a row than it is ok for 4/5 pulls than it starts again.
Anyone have any similar issues ?
No codes? Never heard this one. Sorry
kodak
Disconnect battery and hook up again and try let me know if it works
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
Kodak, do you have some experience with this......I texted him to try this, but we are quickly running out of time for testing!Disconnect battery and hook up again and try let me know if it works
(54 Deg. F. ,here today)
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
I did not see any codes, but am not familiar with this sled..... thanks anyhow!No codes? Never heard this one. Sorry
kodak
Not with your problem as such but I once turned sled on its side and oil light would not come off so when nothing seemed to work I removed battery to switch it with my buddies so I did not run battery dead when hooked up the battery again sled was fine. Again not the same as your situation but easy thing to try my thought was that the sled somehow reset . Your problem sounds a lot like the TORS system but a code should come up on the dash.
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
Sled is fixed!!!!! Dealer changed out a couple switches on the oil system.
- 9K
