Oil pan heater, anyone use one?
NY_Nytro
Grand Island, NY
Website
www.gi-snowmobiler.com
Anyone use an oil pan heater on their sled? Did help cold weather startup ?
We've had a lot of cold weather here in Minnesota this year but I haven't had even the slightest issue getting my sled started.
IMHO a block heater is pretty far down the list of things I'd add to my sled.
I have one on my Attak and they do a good job. It will still turn over slowly but when it fires you have nice warm oil flowing through the motor.
Be careful on the size and wattage. I had an extra one for my truck laying around and it's a little large in size and a high wattage one so I only plug it in for about 20-30 minutes (if it colder then -10F).
Thanks Bigmac for the reply but was looking for people who are using one or tried one.
My Apex wouldn't start twice last week in -20F and again in -28F , maybe my sled is just a piece of crap.
Someone on Ebay sells a 2x3 inch pad rated at 75 watts for $43. A little piece of mind on those cold mornings.
That's sounds like the size you want. Don't leave it plugged in too long though, there's not a all that much oil to heat up. Don't get too discouraged if it takes a couple tries to start it. Once you get that warm oil flowing it should warm it up enough to fire. Good luck.
You may want to add a second pad to the dry sump oil tank... more oil in there. As mentioned, just don't leave em' plugged in too long.
Do you trickle charge your battery between rides?
No I don't. Do you think it's a voltage issue? Should I get one of those small battery tenders for trips?
I tried a small one of the heating pads. Ended up tossing it. The Block Heater in the coolant works a lot faster. Twenty minutes and the sled starts like it is summer time in 20 below degrees F temps. Use some adhesive foil to isolate other parts. They get hot to the touch!
Go with the coolant line heater. Super easy to install and works great. My sled starts great at -40D in West last year. Takes about 10 minutes to install and I think it was about $30 cost. Plug it in for about 20 minutes and the block is warm.
Did you have any starting issues and not running right because of the EFI reading different temps.?
