Viper1050
- Mar 4, 2014
Anyone know if the oil pressure light should light up when key is on engine not running? Does the oil pressure stay locked in . In owners manual after a oil change it says it should.
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
Viper1050 said:Anyone know if the oil pressure light should light up when key is on engine not running? Does the oil pressure stay locked in . In owners manual after a oil change it says it should.
I would not think it would have any pressure once the motor is shut off.
09nytro
Yes , when you turn on the key light will come on , and after the engine is running and you turn it off the oil light will come on then too
YamahaTim
- Sep 21, 2013
- Farmington, MN
09nytro said:Yes , when you turn on the key light will come on , and after the engine is running and you turn it off the oil light will come on then too
True, but that's not saying that the oil is low or low oil pressure, it just comes on. For no reason.
Owsley
On cars, it lights up to tell you it works when you turn the key to accessory.
09nytro
It comes on and off very quick doesn't stay on just the temp light does till engine is warm then goes out
Just checked my sled .
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
09nytro said:It comes on and off very quick doesn't stay on just the temp light does till engine is warm then goes out
X2&3! Oil light comes on briefly with engine hot or cold at startup and shutdown!
