mnman309
I picked up a set of these Ohlins front shocks tonite, they are part# YA350- Compression adjustable only- no rebound.
Ohlins Springs are 00180-84/23 L333
I measured and they are 17 1/2 inches extended and sitting them side by side with the Floats they are the same length and same mounts. I checked and the part# with Ohlins.com and it said they were for an RX-1.
Any thoughts on running them or not running them???
gormleyflyer2002
just a guess but i would say the spring might be a little stout if its for a RX 1.....ok, its somewhat dependant on the damping but the RX was heavier.
can you find out the spring rate ?
I tried some OEM RX1 shocks on mine, a little to much spring. Ohlins might have used a different set up as they usually dampen better and use lighter spring that OEM.
for sure i would give them a go......better than floats IMO
LeeKo
Here are the specs from the Ohlins website for the nytro/apex/rx1 shocks. Notice the length between the rx1 to nytro are close but stroke is different.
YA 862
Technical dataLength 445
Rate 22
Stroke 136,5
Fitted spring 00281-46
Position front
Type S36PR1C2
Year 2008 - 2009
Fits Yamaha Nytro RTX
Yamaha Nytro RTX SE
Yamaha Nytro XTX
YA 560
Technical dataLength 419,5
Rate 23
Stroke 131
Fitted spring 00180-84
Position front
Type S36PC1
Year 2006 - 2008
Fits Yamaha Apex ER
Yamaha Apex GT
Yamaha Apex RTX
Yamaha Attak
Yamaha Attak GT
Yamaha Nytro
Yamaha Nytro ER
Yamaha RS Rage
Yamaha RS Rage GT
Yamaha RS Vector
Yamaha RS Vector ER
Yamaha RS Vector GT
Yamaha RX Warrior
Yamaha RX Warrior GT
YA 350
Technical dataLength 442,5
Rate 23
Stroke 143,5
Position front
Type S36PC1
Year 2004 - 2005
Fits Yamaha RX Warrior
Yamaha RX-1
Yamaha RX-1 ER
YA 862
Rate 22
Stroke 136,5
Position front
Type S36PR1C2
Year 2008 - 2009
Yamaha Nytro RTX SE
Yamaha Nytro XTX
YA 560
Rate 23
Stroke 131
Position front
Type S36PC1
Year 2006 - 2008
Fits Yamaha Apex ER
Yamaha Apex GT
Yamaha Apex RTX
Yamaha Attak
Yamaha Attak GT
Yamaha Nytro
Yamaha Nytro ER
Yamaha RS Rage
Yamaha RS Rage GT
Yamaha RS Vector
Yamaha RS Vector ER
Yamaha RS Vector GT
Yamaha RX Warrior
YA 350
Rate 23
Stroke 143,5
Position front
Type S36PC1
Year 2004 - 2005
Yamaha RX-1
Yamaha RX-1 ER
mnman309
I guess I will be the test mule this winter and try them out. I will have my Fox Floats revalved just in case I need a backup plan.
Unless someone else decides they need these shocks, as I will sell them too if I get a good offer.
