Olins ES rear spring ?????
sledheadgeorge
Ontario
Canada
Which one? I have 6
Olins rear springs question
What is the difference between these springs?
00696-08/40 L145
00696-08/48 L165
00696-11/84 L076
Re: This might help.
putzer said:
http://www.southbayriders.com/forums/showthread.php?t=40165
Good chart but there is no reference to the olins parts numbers I have. Any on else?
The first two springs are 4.9kg rate springs which would have been the stock spring on an 06-07 Apex GT and the third spring is a 5.5kg rate spring which has been used on the 08 and newer Apex GT's. Take a look at the following post as there is more info there regarding the different Ohlins springs available.
http://www.ty4stroke.com/viewtopic.php? ... sc&start=0
