great white north
- Jan 21, 2006
- 2011 apex se
I have an 06 apex gt. After install of 260 hp mcx kit, I can only see max. 7psi on boost guage. As far as I know, this kit is pre-set at 12-13psi. This is the second generation kit that controls boost with an electrical solenoid valve on vacuum line on turbo waste gate. I have checked both, the fuel map and boost map and they are correct for 260hp at 12-13psi. I have installed mcx display and boost pressure on display matches boost guage. Any suggestions.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
90% confident it's an exhaust leak.
FLYBYU
Adjust the waste gate. unplug the solenoid and try that. they have different setup solenoids. we disconnected ours. solenoid changes boost at elevations
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
705 645 4008 BRACEBRIDGE YAMAHA , ONT
CALL DAN , HE HAD THE SAME ISSUES !
NOW FIXED !
NOW FIXED !
