nyrtro 1
- Nov 16, 2017
- cobleskill
- srx/nytro/viper
137 ltx se heavily studded big venom kit with new orange spring over rev hits limiter 6 to 8 times added all i can to heel put another washer on mid fine on ice real bad on snow set back to 2/3 is it possible to much rear spring for n/a with air box mod only
Kenzie
- Feb 27, 2015
- Viper ltx se 137 turbo
What orange spring primary or secondary? Also do
You mean limiter on launch or top speed running?
ViperBill
- Dec 14, 2014
- Linwood mn
- 14 viper rtx
Had the same problem regardless of set up finally went to gates belt and solved problem. I think the yamaha belts are too hard and slip at low ratios.
yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
Why did you change the secondary spring in the first place? What was wrong with what you had?
Pm Shagman or NosPro also.
Another candidate for 14.5mm rollers in primary or go back.
yammitrip1
- Sep 28, 2017
- Rome ny
No slippage here, stock pink spring at 60 wrap with washers underneath. I don't even think I should try this orange spring, it seems this unit is just to stiff. Made more for boosted sleds.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
700 flawless ski lifting miles so far this year with TP orange secondary 3-3 on 5 psi turbo viper, running last year's gates cf 8dn length belt with over 1600 miles on it
Kenzie
- Feb 27, 2015
Belt choice and helix angles I believe play a big role in spring choices. What works for one may not work for all. I see on sidewinder side a lot of talk about this and they really have issues with tune ranges and different helix manufactures.
And Turbo is a huge difference. Just like that Ulmer red spring he had me try. Stiff as heck. Could barely change the belt and I never got it to work well for me. Gave it to BoostedNytro and he is still running it on his sled today. Difference is alot more hp. Remember the #1 rule though. Always tune clutching as much as possible with the primary.
nyrtro 1
- Nov 16, 2017
- cobleskill
- srx/nytro/viper
this is what i am thinking the new orange spring is to much for n/a works well on ice with good hook up get in snow spins and hits rev limit was wundering if anyone else had this happen with big venom kit never got original spring went right to new spring running original helix
Alsim
- Oct 6, 2014
- LTX SE 2018
Try it at 3-1 wrap .137 ltx se heavily studded big venom kit with new orange spring over rev hits limiter 6 to 8 times added all i can to heel put another washer on mid fine on ice real bad on snow set back to 2/3 is it possible to much rear spring for n/a with air box mod only
