Overheating at idle or slow travel
klondike22
northern New York
15 SR Viper LTX SE
We have a 2014 viper xtx with 4000 miles that recently has been overheating at low speed. On further checking the fan had blown the fuse. New fuse worked fine- fan cooled as it should and turned off when supposed to. Then the motor starts to overheat again..lo and behold the fuse is blown again! Wires appear fine- no bare areas- we are puzzled.....an ideas? Thankx.
The relay won’t blow the fuse. My guess would be the fan motor drawing to much current or a rub through in the wiring shorting out to ground somewhere.
Connect an amp meter in series with the fan motor to see how much current it is drawing. You could do this with an external power supply or battery too if you didn't want to have the sled running. I see that the fan is powered from the ICS fuse(15 amp) and I would be surprised if the fan drew more than 4 amps.
