Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
It seems like we have all had some overheatings issues on occasion with our 4 Strokes.
I was doing some research on a simple add on "ICE SCRATCHERS" and here is an excerpt from a test that was done, (With and Without)
The affect on water temperature was even more impressive. We ran three test sleds in this situation. First was the above mentioned 2000 800RMK with 2x156 track. Second was a 2001 800RMK SCS with the stock 2x151 track. And third was a 2000 Arctic Cat ZR800 with Genesis 890 motor and 2x141 Challenger track. All three machines were equipped with Avenger gauges with water temperature probes. In deep fluffy powder all three of these machines run water temps in the 125-130 degree F range. We ran the machines down a packed powder trail, very typical of what one sees in Western riding areas when going to or coming from backcountry riding areas, for 5 miles with the scratchers snapped up out of the snow. We watched the water temps on the Avenger gauges closely. After just 2 miles the Genesis Cat was above the 165 degree F threshold we had established as our upper limit and we had to pull over and cool it down. The two RMKs both saw temps climb to just over 160 degrees F with the '01 settling right at 163 F and the '00 at 160 F. They held this temp pretty consist over the five mile stretch, making us nervous about exceeding 165 F, but never causing us to stop and cool them off.
Snow is thrown off the scratcher onto the track, slide rail, and tunnel.
We then deployed the scratchers and ran the 5 mile stretch of trail again. The results really were amazing. Engine temps all started at 125-130 F for both tests, but with the scratchers deployed the RMKs never exceeded 135 degrees F and the Genesis powered Cat settled at 142 degrees F and maintained. We even tried riding harder, slower, drag raced the sleds, and even purposely sought out the spots on the trail with the least amount of snow. Nothing could cause the temps to climb above that 135-142 F temp range. Those are indeed impressive results.
Over the course of this season we have ridden the sleds in all types of conditions, several times in even lower snow conditions. Not once have the machines even come close to over heating when the scratchers are being used. They are even more valuable in spring riding conditions when you leave the truck early in the morning and ride up snow that is as hard as the back of your head. The scratchers just keep doing their job. In this situation we have ridden the entire day with the scratchers down. We also found them very handy when towing a broken sled out to keep the towing sled cooler as your moving slower and not throwing as much snow off the track as you might normally.
WarriorBeads
- Dec 4, 2005
- Peterborough, Ontario, Canada
- 2004 Rx Warrior
I'm going to be adding a rear rx-mountain heat exchanger to my warrior to help the overheating. I think it's a 'cleaner' fix than this ice scratchers.
However, that's a great review and very informative. If the extra heat exchanger doesn't do the trick, that's the next step.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
I installed a warrior/attak rear heat exchanger on my 136" '03 RX-1 Turbo. I've had the light come on only once last season running at glare ice and very low snow conditions for 5 miles, this was without scratchers installed. Only problem I had was wearing out a set of stock sliders with less than 100 miles on them, they melted away, a set of ice scratcher would have been nice in those conditions.
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
rxrider said:I installed a warrior/attak rear heat exchanger on my 136" '03 RX-1 Turbo. I've had the light come on only once last season running at glare ice and very low snow conditions for 5 miles, this was without scratchers installed. Only problem I had was wearing out a set of stock sliders with less than 100 miles on them, they melted away, a set of ice scratcher would have been nice in those conditions.
To me the biggest reason to use them is the slides! I agree it also helps keep the engine cooler but if the snow is that hard packed the temp is probably cold enough to where engine overheating won't be a big issue. They really help keep the slides from melting especially on glare ice where without them your liable to stop and have them stick to the track. All around they are a great idea regardless of whether or not you have the rear cooler the combination of the two makes the most sense.
I installed these on my my mountain sled running nothing but trails last year and had virtually no slide wear. I have a rear cooler installed so dont have any overheating issues.
http://www.ty4stroke.com/viewtopic.php? ... scratchers
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Sled Dog said:I installed these on my my mountain sled running nothing but trails last year and had virtually no slide wear. I have a rear cooler installed so dont have any overheating issues.
I had a set of those scratchers installed, they worked great riding on the trails, but they could not take the abuse of riding in low snow conditions in a terrain with lots of rocks surfacing all over the place, typically when riding off trail in the mountains. My solution to the hyfax wearing problem was a set of Hyperfax sliders, they do not melt down, vitually no wear after 1000 miles last season.
Len Todd
Doesn't 125 to 145 degrees F seem a bit cold? I used to run my 2 strokers at 165-180. My RX runs 165-190. Just seems like 125 - 145 seems a bit too cold.
rx1mtn
I have both the rear heat exchanger and ice scratchers from Mountain Performance. I too have problems with the life of the ice scratchers, but I have noticed that my hyfax lasted 2 to 3 times longer than with out. The problem is that untill this year, Mountain Performace only sold the complete kit, now it looks like you can get the scratchers only.
