Oversized Rear Wheel Kits- Are they worth it?
rx1007
Hagaman N.Y.
Anyone? I am still looking for info/suggestions on oversize rear wheel/offset axle kits for an 03 RX-1 shorty. Are they worth it? If not, why? If yes, which one(s) is the best? Any help would greatly be appreciated. Thanks and hope everybody has a very merry christmas and happy new year. Jeff
stock wheels are 7 inches the easiest swap is to a yamaha 7.5. the 6 idler wheels can be replaced with polaris indy wheels(5.35 vs 5.25) these changes will reduce slider wear and cost less than aftermarket offset spacers.
rear idler wheels
i have removed my stk 7 in wheels and replaced them with yamaha 7.5 in wheels this works if you use the larger idlers as well.
Greatly ruduced rolling resistance of the track. Issue is clearance. 8" wheel with studds will probably hit the die cast piece under the muffler. Mine did stock.
