Greetings everyone. Snow is on the way and I am having a problem with battery drainage. New battery last year. Had a few instances where battery needed to be jumped to start. Battery was taken out for summer. Fully charged and just recently installed 3 weeks ago. Battery will noot spin over motor fast enough to start. Voltage is 11.2. There is a voltage drop in system. How to check and any possible culprits. Keep the tracks on the ground guys when the snow flys.
Could not leave it alone. checked plug and BINGO. Will replace and check drain. Thanks Steiner for the prompt reply and heads up.Check the white connector beside the battery that plugs into the starter relay for corrosion.
