SPROCKET, CHAIN DRIVEN (40T)
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
Jason the reverse models lower gears start with a 8fb number. I am not aware of any 40 tooth lowers for the reverse models. Fill me in if your onto something
deshkae
There is a 40 tooth lower gear. Check the parts in a Moutain reverse Kit. The moutain has a 40 tooth lower gear and the shorty track has a 38 tooth.
According to the Yamaha Parts Finder linked to this forum. The part number for
40 tooth gear, 8FB-47587-00-00 (for a reverse gear kit)
38 tooh gear, 8FB-47587-80-00 (for a reverse gear kit)
Never heard talk of this when i baught mine all
was available was a 39 T lower gear for reverse
on the mountain machines and 38T for shorty's :?: :?:
TB
TB
deshkae
i assume you have a 2003. In 2004 the reverse gears were recalibrated and now the moutain kit for 2004 which will fit on a shorty has a 40 tooth gear. If you have a reverse kit on your machine and it has 38 or 39 teeth you can order just the 40T gear and it will fit perfectly.
I found all this out by mistake. My dealer sent me a Moutain reverse kit and I installed it on my shorty. Come to find out it had a 40 tooth gearing. Some told me to keep the 40t gear becasue I would be faster up to about 100 but would loose some top end. I called my dealer and he is sending me the 38t gear as a swap. I am kinda anal about those things. Darn it if it's suppose to be a 38t gear then I want the 38t gear. Besides my dealer has jerked me around on this whole reverse kit anyway and he is going to send me what I paid for.
