modsrx
- Feb 2, 2013
Can u lean out the sled for the cold start ...way to rich on cold day ...with a pc3 ? Or the pc3 will have only effect after the sled fire up
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
I always found my 2011 Apex cold started much better with the PCV from Ulmer with his mapping installed than it did stock. I’d get in touch with him and discuss. He likely has more experience than anyone when it comes to altered fuel mapping on Apex based sleds.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
I leaned mine out 2-3% at idle because I thought it was too rich on cold starts and even after it warmed up. Warm running idle a/f on mine is right around 14:1 now. Before was in the mid 13's. Too rich at idle IMO.Can u lean out the sled for the cold start ...way to rich on cold day ...with a pc3 ? Or the pc3 will have only effect after the sled fire up
Right in the 1750, 1500,1250 column's.
modsrx
- Feb 2, 2013
So the pc3 will help the time the sled crank to lean it ..i know it will on warm up just not sure on cranking time
