STORM-CHASER
my new phazer idels high when its cold and latter settles down. Is this normal I was thinking with efI is should be the same. are they all doing this.
phaze5
should run @27002800 for acouple minutes idle down to 2200 then add snow and ride it
Phazed-Coug
Idle speed after warm up should be 1700-1900rpm
AS per the service manual(and I believe the owners manual)
jp@weknowsnow
its normal.. and most time's when warming up or high idle you can't shirt into reverse
this seems to be the dead button issue
phaze5
yes after its fully warmed up. i see mine cooling down rapidly after a good ridin and have to wait for the high idle to lower down to begin the beating once again just doesnt seem right to me .jp@weknowsnow said:its normal.. and most time's when warming up or high idle you can't shirt into reverse
STORM-CHASER
thanks guys Now I fell better, I also have the dead spot going to to reverse untill the idel goes down.
Phazed-Coug
You just have to adjust your warm idle to specs, then it should let you engage it(of course you may need to rock the sled a bit to get it to engage, but I think thats normal)
Guys,
Its a good thing to let your sled warm up..It won't go into reverse at high idle for good reason.With the efficiancy of this motor, I don't think you need to worry about it sucking gas..Let it idle high for a few, get warm and then rock on!![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
Yeah mine does high idle untill it warms up then it idles at around 1700 to 1800. Right around 1725 to be exact.
30yearsleder
Unload yor sled first start it then put your gear on and by the time you have your suit gloves and helmet on it will be ready to be run hard. It is normal for this sled to fast idle 2500 or a little above for a few minutes then it will settle back to between 1700 and 1800rpm when warm. Its a great little engine and once its warmed you can run it hard as long as you like it can take it ! There is also an idle adjustment behind a rubber plug in the right front panel as you are facing it if it does need to be adjusted but I doubt it really need any adjustment .
STORM-CHASER
30yearsleder said:Unload yor sled first start it then put your gear on and by the time you have your suit gloves and helmet on it will be ready to be run hard. It is normal for this sled to fast idle 2500 or a little above for a few minutes then it will settle back to between 1700 and 1800rpm when warm. Its a great little engine and once its warmed you can run it hard as long as you like it can take it ! There is also an idle adjustment behind a rubber plug in the right front panel as you are facing it if it does need to be adjusted but I doubt it really need any adjustment .
I adusted it it was running 2900 cold 1900 warm, took it down to 1700 warm make a differnts.
