Phazer gear reduction 2007
kirkswim
sudbury ontario
Canada
Yamaha RXWarrior
Looking at a used 07 phazer with 7300kms. Does anyone remember the limit for milage for the gear reduction. What I mean is if your gear reduction was going to blow up what milage would it do it by?
I don't remember the km's but 7300 is way past it as I remember.
Does it have the other updates for the 07?
I have an 07 Gt with 6000 kms and I remember someone saying if it goes - it goes early. I think you and I are good.
Okay sounds good. As to the updates I have asked but the seller has not replied, he also posted in the ad that the battery was not charging. Is this common? Probity just a new battery needed I hope.
If you get the vin any dealer can run it. There may also be punch marks on the vin on the tunnel for the updates.
If its the original battery chances are its done. I just replaced mine. The battery wouldn't charge over 90% and starting would drain it down to 60%.
