PZJW
- Feb 4, 2020
- Barry's Bay
- Phazer GT
Looking for information about rear shock choices for phazer, I've read posts that I can use shocks from a ski doo but not sure what model and year will fit the phazer looking at royal distributing catalog need to know exact models of skidoo that'll fit
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Personally, I have a set of shocks off a Skidoo SC4 skid, SC3/4/5 SHORT TRACK model all use the same length shocks which are very close the same length as the Phazer shocks. You will need to stack some washers on either side off the eyelets on a few of the mounting points as the Doo eyelets are pretty skinny, especially on the center shock.
PZJW
- Feb 4, 2020
- Barry's Bay
- Phazer GT
Okay thanks but do you know what year and model skidoo that uses sc4 suspension with a 121 track I'm not familiar with skidoo catalog doesn't tell me anything about sc4 just make and model
PZJW
- Feb 4, 2020
- Barry's Bay
- Phazer GT
Anyone know exactly what year and model will work I understand I'll have to shim the side that's not a problem. Would like to order both rear shocks if I can. Thanks
PZJW
- Feb 4, 2020
- Barry's Bay
- Phazer GT
I've removed the rear skid checked all movable links and shafts. greased all pivot points, replaced all idler wheels and brgs in rear skid. Installed hyper spring spacers, adjusters on high. made my own anti bottoming kit out of skateboard wheels with bushings, but still find the sled on the the trail bottoming. Center shock cranked to hardest. Is there different shocks or springs available
sweetjob
- Sep 14, 2007
- minneapolis, mn
- blownconcepts.com
- 2007 yamaha phazer
Id suggest doing the hygear upgrades and be done.
bradmopar
- Feb 4, 2011
- Langham,Saskatchewan, Canada
- 10 Yamaha Nytro XTX,08 Phazer MTX, 95 Polaris 500 EFI SKS, 76 John Deere 300
I just replaced the rear shock in my Phazer mtn. I installed a Kimpex Nitrogen shock. I picked up a rear shock for a Skidoo Mx Z 2004-05 p#004-513N7. Bolted straight in. I rode it today and it worked excellent.
