ymhajoe
- Jan 25, 2014
- Austin ,mn
- 2011 PHAZER RTX,2000 SXR 700, 2003 VIPER MTN
What is the K&N oil filter part number for 2011 phazer rtx or where can I get a filter wrench that fits a yamaha filter and will fit in the small area they give you to get the filter loose?
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
KN147 I believe
ymhajoe
- Jan 25, 2014
- Austin ,mn
Okay thanks for the info, but now I need to know where to get a filter wrench to get the yamaha filter off. Any ideas ?
Gone Blue
- Oct 11, 2006
- Howell, Michigan
ymhajoe said:Okay thanks for the info, but now I need to know where to get a filter wrench to get the yamaha filter off. Any ideas ?
You wont be able to use a filter wrench to get the stock filter off unless you take the front sub frame off.. Pierce the filter with a screw driven to break the filter loose then use a strap wrench to get it off.
G.B.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
I have a cup filter wrench that is suposed to go in a socket wrench. Instead I just put a carriage bolt through the square hole and a nut on the outside. Just jamb the nut so it can undo. Worked great and I've changed about 6 filters without removeing the subframe.
Pa Teeny
- Nov 18, 2013
not sure what you mean could you post a picture ..
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Pa Teeny said:not sure what you mean could you post a picture ..
Sure but I can't until the weekend, I don't have it at my shop right now.
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
I just used a pair of channel-lock pliers to remove stock filter, was easy
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Voda2000 said:Pa Teeny said:not sure what you mean could you post a picture ..
Thanks![]()
Sorry it might be a few weeks now becuase of something that change my planes for the weekend but I will once I get a chance.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Yup, $5.99 at OReilly and they come in multiple sizes. Mine fits my sleds and my Buell.
http://www.oreillyauto.com/site/c/d...lter+wrench_-1_1821&keyword=oil+filter+wrench
Black7
- Mar 23, 2013
- Michigan
- 2015 SR Viper X-TX
2016 SR Viper S-TX 137 DX
I have an MTX. I could not figure out how to get the KN filter past the frame without getting the oil cooler clear first. The "nut" on the end of the KN filter took away any clearance that you get with the stock filter. FWIW, I'm going back to stock on the next filter change.
Maybe the RTX sub-frame is different and you won't have the clearance issues that I had.
Channel Lock Pliers here:
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Shouldn't be different between shorties and the MTX for the front sub frame. If you unplug the oil pressure sensor and move the idle adjuster out of the way, you should be able to get it out. It's tight but doable and only goes one way. I use K&N and the nut just makes it easier for me.
donkickit
- Sep 23, 2007
- Upstate New York near Albany
- 2014 viper ltx se
X2 on the channel locks, they work great to get filter off.
