prozac500
I have a 07 phazer Mnt light with 2000 some miles on it. I was thinking about selling it. It has arcticfx sticker kit, GYTR front shocks, GYTR front and back bumper, prowermad handguards, Plastic Bushing And Steel Collar for the steering here is a link http://www.ty4stroke.com/viewtopic.php?t=76976, skid plat, and OFT steering block. It also has new slides on this year and Cold Air Intake from Schmidt Bros motor sports. Here is a link for ya. http://www.schmidtbrosmotorsports.com/Y ... dules.html. Just did a oil change this year. I used Amsoil. I closed off the hole in the back of the tunnel, extended throttle Cable. I have all the recalls done this year which are ball joint 2, MTN ecu kit, hinge rivet, and front upper arm. When I went back to the dealer about three weeks after I got them done three new ones came out which are steering idler arm, altitude compensation, and joint connector. I did not get the new recalls done. Here are some pics for ya. If I for got some thing I will let you guys know.
prozac
prozac
