Phazer MTX MCX turbo, Clutching
yel_low
Northern Sweden
i have MCX turbokit, With their clutchkit, BUT i still hit the limiter pretty often, and thinking of changing Helix to a more agressive one, and eventually change secondary spring to one with more backshift, anyone doing that or has some god ideas?
im very satisfied with Phazer and MCX kit :yam: :Rockon:
Buy a set of adjustable weights like Heavy Hitters or Supertips, you need more weight in your primary to keep rpms down.
Yea you need more weight
yel_low said:
anyone who got heavy hitters that can tell weight? there are several different.. :)
There are 4 Yamaha style Heavy Hitters. A 48, 53, 58 and 64 gram base. From there, you add weight in the heel, middle and tips of the weights.
Turboed Apex/Attak models require the 64s. I would imagine a Turbo Phazer would use the 48g base, then tune from there.
Call Prince George Yamaha , they are the Canadian dist for MCX. talk to Don ,
THEY HAVE IT NAILED !
i would, but im in Sweden and he is in Canada, some language problems may appear, and some time difference to.
some nice guy that could help me? i think my MCX Weight is about 60grams around, 20grams heavier than stock are they.
:-o
CALL MCX , they supply clutching now with the new kits !
