Phazer Mtx , Turbo or SC
yzman
Goose bay,NL Canada
Should i Supercharge or Turbo my oh Nine phazer mtx, Im looking for something to run off pump gas , and be in the 130-150 range for hp , any sugestions?
where do you ride? trails, mountains. you want ease of install or highest hp? S/C is eaasier to install and less headache over all, but will never be able to keep up with a turbo.
And don't forget all the added stuff you need to tune it right. clutching, air fuel gauge temp, boost gauge. added cooling, now traction is an issue more pics or bigger track, anti ratchet drivers gearing. the list goes on.
I say turbo cause that what I run but a S/C does have its place for the right application
Ive got my phazer extended to 151 , and im running a 151 x 14 x 2.3 inch challenger . i was thinking about going with a super charger because of the easy install . and isnt the sc more relieable?
The S/C is faster install and less evasive on the total sled, no header to replace, or bulkhead to cut etc. You can adjust boost by pulleys put lb for lb a turbo is faster and will make more power. S/Cs are fun trail sleds. never seen deep powder so don't know how they go with that. And I can only speak from experience on apexs S/C and Turbos
Either way you will love boost!!!
