So my 2014 Yamaha Phazer Rtx has sloppy steering and I figured to ask you guys for help about which parts I should change in the steering system. I know there are lots of threads discussing about these problems but I can't manage to get to a good picture about which parts you should change to fix the slop. If someone knows the parts that would help against sloppy steering please let me know which parts in the steering and arms helps to fix the problem. Thanks!
Okay, Thanks! So what would be a good setup of kits to replace bad parts? Which kits should i buy to basically fix the hole front from steering and handling sloppiness and from where can i buy them?
