When I turn on the key to my 07 Phazer the fuel pumps charges but when I attempt to start the sled I only get it to click. After several clicks it will sometimes start (but not always). Battery is fully charged and in new condition. This seems to happen more when it it very cold (15degrees and under). If I bring the sled inside and warm it up the issue usually goes away.
Is this symptomatic of the starter problem i.e. bolts loosening? Can the starter be checked for looseness without removing the front end.
Any help would be appreciated.
Thank you
Thank you
