Nytro Fx
Hey I need some input, we just bought a 07 phazer gt and the rear suspension is currently set up very poorly. I do not know my way around the phazer yet so I need some help.
First, with the current setup I stand on it and squat it bottoms out, and if I stand on the rear bumper and compress it and jump it shoots me like a catapult up. After a ride she said that in the bumps it will jump up and hit her in the butt, so too much rebound?
Second, the rider weights around 115 pounds geared, semi aggressive rider.
Cameron.
Cameron.
zackn291
Probably a little too lite for the machine if you ask me.
I'd start by setting the torsion spring to medium. And also loose some rebound!
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
sounds like you may have a broken link - look at the bottom of each shock where they connect and determine if the link to the two shocks is cracked.
marpolsdofer
It should have the stock suspention settings in the GM (genral manual). I think it does to in the TM.
fraolib
if its shooting back up thats probly gonna b a blown shock
Nytro Fx
woolyviper said:sounds like you may have a broken link - look at the bottom of each shock where they connect and determine if the link to the two shocks is cracked.
just dropped the skid and that is what happened
Ruckus
Make sure you do all the 07 upgrades!
Is alot of info in here to help
http://www.ty4stroke.com/viewtopic.php?t=35515
- 24K
