lodgebay1971
Can you put a bigger track on the phazer? will she pass a 1.75" or a 2" track?
The short answer is yes. I think the MTX comes with a 2" track (somebody correct me if I'm wrong). If you're thinking of running another track, you'll need to make sure it's not too wide.
yammiebhy
so, it would fit on the short track?OVR4D said:The short answer is yes. I think the MTX comes with a 2" track (somebody correct me if I'm wrong). If you're thinking of running another track, you'll need to make sure it's not too wide.
UP bushman
Taller lug tracks fit with no problems but not any wider than 14 3/8". That is cut down of course for there are not many options out there. I have a MTX with 1.75" Back Country track with 9 tooth drivers with lots of room.
I put an inch and a half on my short track 07 and it worked awesome!!!
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
i got a 151 x 3 on my phazer
Here is some good info about customizing your Phazer with a taller track starting from a wider and cutting them down to fit your needs.
http://www.ty4stroke.com/viewtopic.php?t=80160
sobfrogg
I am intrested in the 3" track. Leno where did you find a 151" 3" track? What pitch is it??
My ton could use a litle more paddle.
RIBIT
RIBIT
