PICKED UP A LOW MILE 06 GT
JERSEYJOE
KEARNY, NEW JERSEY
I actually have an 06 with about 16000 miles. Did a bunch of updates but I forget some of the specifics so questions: AM I MISSING ANYTHING?
FRONT END: lower the front end until the A Arms are parallel and install 13 mm sway bar.
is the 13 mm bar still available?
RUNNERS: Install Duce bars 4 1/2 and shim rear of ski down
SKID: Replace the W arm with a later model reinforced arm. Is the correct replacement
arm from the 2008?
MONO SHOCK: Remove and send to HYGEAR
HAND WARMERS: Replace with 2008 warmers.
is the 13 mm bar still available?-YES
RUNNERS: Install Duce bars 4 1/2 and shim rear of ski down Correction install aggressive Snowtrackers thank me later.
arm from the 2008?-YES
MONO SHOCK: Remove and send to HYGEAR-YES
HAND WARMERS: Replace with 2008 warmers. Correction Rewire 2006 bars with 2007 harness they will be the warmest grips you ever had.
A 13 mm sway bar is still available through Travis at Barn of Parts. If the front end is loose you may want to install
Oil Lite bushings as well.
Personally I would go with aggressive Snow Trackers.
The W arm from a 2008 and up are the reinforced ones. You could also go with DuPont hyfax.
You can get Yamaheaters and thumb booster from RoczToyz at yamaheater.com for hand warmers.
Check the exhaust donuts for wear so the Y pipes don’t crack.
Ok the subject of the reinforced W arm. The 2008 GT arm is part number 8FT47331-01-00. The 2006 arm has been replaced by part number 99999-03774-00.
Which is the right one to order?
