So I picked u my brand new xtx 2014 wow a thing of beauty , so my question is , is there any must dos to this sled that I should consider Ty , oh by the way it comes with dupont sliders
Florida Snowman
- Sep 19, 2012
Congratulations! You are going to absolutely love your new toy!
Add snowtrackers to the ski's. With the fantastic power steering system they make the sled rail around turns.
http://www.snowtracker.com/en/Library/compositeFR.jpg
Enjoy!!
Enjoy!!
Which ones do u recommend aggressive or semi ?
trailhed1
The 14 XTX comes with the Yamaha Tuner Skis not sure you can use snowtrackers with them. You will need to change Skis to have Snowtrackers i believe.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
trailhed1 said:The 14 XTX comes with the Yamaha Tuner Skis not sure you can use snowtrackers with them. You will need to change Skis to have Snowtrackers i believe.
The Tuner skis are a big upgrade from pass Yamaha skis. Take it for a ride before mod you maybe happy with it from your pass sled.
I just noticed it has a much smaller gas tank , any tips on how I can carry more gas along ? What have others done ? Thanks
That's odd. I thought they were all the same. How much fuel does it say it holds?xtx said:I just noticed it has a much smaller gas tank , any tips on how I can carry more gas along ? What have others done ? Thanks
34.5 liters
9.2 gallons , 34.6 litres
Just looked in my manuals. 07 holds 38.3l or 10.1 gallons. 2011 holds 34.6l, or 9.14 gallons.
Yamaha Canada's website shows snowtrackers for tuner skis.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
it has the tuner skies already, no need for any other skies or snow trackers. I switched to a set of the tuners last year with dual 6" carbides and it handles great now with no darting whatsoever. i added more weight to the front and now rails with hardly a hint of any pushing. I'd ride it first and get the suspension tuned to your liking before making any other changes
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
XTX please add your location to your porfile it is a site rule thanks.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
APEX 06 said:trailhed1 said:The 14 XTX comes with the Yamaha Tuner Skis not sure you can use snowtrackers with them. You will need to change Skis to have Snowtrackers i believe.
The Tuner skis are a big upgrade from pass Yamaha skis. Take it for a ride before mod you maybe happy with it from your pass sled.![]()
At least we have a couple of sane members who recommend-- RIDE IT BEFORE YOU MOD.
How can many of you make "wholesale recommendations" when the new sled owner has not even ridden one (1) mile? In this case, HE doesn't have a specific problem --why would you recommend a specific answer?
do not be suprised on the 1st big bump at speed if you feel a snapping/crunching from the rear suspension. shocked the heck out of me on the 2013 jan ty ride.
I will recommend that you check the toe in before you go riding as mine was set almost 1" toed out.
the only other setting I would recommend is setting the torsion springs to soft unless you weigh almost 300lb+ as it will spank your #*$&@ in rough trail.
I leave the shock settings to you as that is for your personal preference .
I bought my apex as nos on dec 31 2012 and the rear torsion spring setting happened on the side of the trail towards the end of the 1st day. viperdave and others told me I would be turning those to soft before the end of the day. I wish I had listened to them sooner.
