jcrowton
Thanks Worcester, Mass
flyingpig
Nice job Darth! Looks like the black beauty. I should send you a picture of my son in the apache with a darth vader helmet on.
paulrxwarrior
jcrowton said:Thanks Worcester, Mass
Where are you in Worcester....Spencer here...sled looks sick, would like to see it up close
Nice Rumble
With all that rise I assume you needed longer cables?
jcrowton
Nope the cables reach with no problem, actually you can put on up to 10inches of bar rise
jcrowton
paulrxwarrior, i am right outside of worcester in boylston/shrewsbury
Nice Rumble
What part #'s did you use? All I can find is a 5" riser on their site.
http://www.powermadd.com/products/nonpi ... locks.html
jcrowton
you have to buy the pivot riser blocks, and you use the arctic cat blocks, they are the same part numbers yamaha and arctic cat are universal, then you buy the pivot adapter kit, i buy my parts through dennis kirk, part # for the 6inch block is 59-2595 $37.99 and then you buy the pivot adapter kit part # 59-2892 $47.99
Nice Rumble
Cool! Thanks J
jcrowton
No problem any other questions just ask
Pureadrenaline
- Apr 6, 2005
- SW Michigan
- www.myspace.com
sweet lookin sled!
Mrplow
- Sep 18, 2005
- Madison WI.
- www.proscapesllc.com
How tall are some of you that are raising your bars? I am 6' 3" and need/want taller bars for the stand up riding that I love to do. My question is will 8" be enough and how do you like them while sitting as you have to sit to rail through the twisties-and that is just as fun?
jcrowton
I am 5'11" and 8" seems perfect, with you being 6'3" i would put on 10" of rise, with the 2" pivot adapter and an 8" bar riser
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
MrPlow Im 6'3 as well.
I can stand up with ease now with the same exact setup as his.
Im sure you WILL need handguards as you will be directly in the wind and elements.
Standing is perfect , as well you can tilt the bars ahead to where they should be s\positioned in the 1st place.
If you riased them without the pivot you would be standing near the middle of the tunnel.
If you like to radar run, you will prob put them back down as with them up that high you are a great big parachute.
Scott
Scott
Sidewinder
- Mar 19, 2005
- Ontario Canada
- Waterloo
