Picture of Zbroz front end on 09 Nytro please?
MRFUSION
Peace River Alberta
Canada
2011 Custom Built Nypex
2008 Custom Union Bay 980 MM Chassis
Does someone have a picture of a Zbroz front end installed from the side if possible. I called Zbroz before installation because I was missing the spacers for the upper a-arms and got a run down on the install. I installed the upper a-arms like he explained but looking at it the shock is not at all centered in the a-arm and the spindle is pretty much strait up and down. The ball upper ball joint is off center towards the front right now like I was told but I would like to verify. Thanx for any help
you might want to check if you have the a-arms installed right and if you do not have two of the same side.
