pictures of handguards
powermadd w/hand mirrors screwed on after originals fell off
http://i244.photobucket.com/albums/gg25/snoway_photos/100.jpg
does the parking brake still work with those? i have those on my old vmax and the mounting bracket is in the way.
I have Powermadd mounts and guards on my Rage. I would post some pictures but my sled is up North. The straight mount goes on the right/throttle side and the drop down mount goes on the left/brake side. If you put on the left mount so it drops down under the brake lines it fits just fine and does not get in the way of the parking brake lever. G.B.
GB,
My sled's up north, I'll have to check it out, but I think I tried it under the lever and the gaurd won't rotate to be high enough.
snoway said:
GB,
Snoway, I should be getting my sled from up North in the next week or so. I can take some pictures of my set up. The knuckles and back of my hand dont get cold. It is my finger tips. So look where your hand sits on the grips when you set up your hand guards. Maybe you dont need to set your guards that high. I have the mounts inboard of the brake and throttle blocks and they fit just fine. G.B.
I have the fx guards on mine. More protection than the stockers but might ge tht dumbo ears next year.
I have 2 sets of Powermadd handguards with mirrors on the sleds. Sorry, no pics yet. The parking brake clears the left side mounting bracket. Just keep the bracket loose during installation and set the parking brake lever and adjust the bracket by wiggling it under the brake lever so there is proper clearance. Then tighten it up. I liked this set up as you can easily buy replacement parts if needed.
The Skinz guards look nice. Anyone have and like them? and have pics?
I'm in the market also since I haven't found a medium windshield that I like. I have full FXR gear and never cold but my hands tend to get cold from time to time. I think bigger hand guards will help.
I brought my sled home last night from up North and snapped a couple pictures of my Powermadd hand guard mounts. I have the curved mount on the left/brake side. Both mounts are located inboard of the brake and throttle blocks. It curves up from under the brake block. Let me know if you would like to see any additional pictures. G.B.
