Ndoggct
- Aug 25, 2018
- Ct
- Looking for 18 sidewinder
i just purchased a set on 5.7 pilots for my 18 Ltx le
It comes with 6” carbides
Is everyone running the outer 4” on the 5.7s or am I ok with a single 6”
Thank you
Thank you
uofm
Go with Snowtrackers. Best thing you can do for a Yamaha.i just purchased a set on 5.7 pilots for my 18 Ltx le
Thank you
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Pilots come with square 4" center in the kits, or on new SKIDOO sleds.i just purchased a set on 5.7 pilots for my 18 Ltx le
Thank you
So the 6" you got might be something else, hard to say.
For this chassie, you need more carbide on the pilots to reduce push. I recommend a full carbide in center which is 7.5" actual but many manufacturers call them 8". Im running the ACE 8" this year from woodys. The ACE is taller and rectangular. I have run the 8" executive from woodys in past(1/2" round host bar) and they work pretty good too.
IMO you MUST run outer carbides, otherwise the ski outside edge will get worn off prematurely. Most of us use the stock 4" square bars(7/16'' host) for outers. You can run larger outside if you like, I tend to like the smaller 7/16'' host outers. I guess you could try the 6" you have outers if you like.
If you ride aggressive at all, you want more in center then 6" and you want at least a 1/2" host bar min IMO.
Dan
Ndoggct
- Aug 25, 2018
- Ct
It was a package that was already put together that had Woodys 6”
I was going to try to run that in the center and add 4s to the outside if everyone thought was needed
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
So snowtrackers do fit pilot skis,interesting I do hear they turn better than most carbides that fit the pilot,plus no tracking thru other ski tracks,and not twitchy. My onlt concern is RR tracks and road riding and crossing. There are trails that we need to ride the edge for 1/4 stretches to pick trail back up,how do they last,and how are they for loading onto trailers?Go with Snowtrackers. Best thing you can do for a Yamaha.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Which 6" are they? You can try them, but I would not bother.It was a package that was already put together that had Woodys 6”
If you run big wide open trails, and dont do alot of carving in tight twistys, you would be fine.
If it were me, Id put those 6" outers, and buy some 8" centers.
Dan
Ndoggct
- Aug 25, 2018
- Ct
Dan
thanksWhich 6" are they? You can try them, but I would not bother.
Dan
This is new to me, so how exactly do I know where to mount the outers on the 5.7 pilots?
These have to be drilled correct? Thanks greatly
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
I have the pilot 5.7's with semi-agg snowtrackers on my 06 Apex and have nothing but good to say about the combo.Go with Snowtrackers. Best thing you can do for a Yamaha.
I ride mainly trails, if I rode more powder I would go with the pilot 6.9's and st's.
Ndoggct
- Aug 25, 2018
- Ct
Honestly I do not want snowtrackers that is why I bought the pilots, but thx for replies
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Why,what don't you like about trackers?Honestly I do not want snowtrackers that is why I bought the pilots, but thx for replies
uofm
I have done pilots with what you are doing and I have done pilots with Snowtrackers. The pilots with Snowtrackers are night and day difference. The Snowtrackers are what make the sidewinder into what it should be. I was reluctant of trying them years ago. I put pilots on my Nytro. It was ok. I then put the snowtrackers on and it became a totally better machine. Good luck with your new setup. It will be better than stock.Honestly I do not want snowtrackers that is why I bought the pilots, but thx for replies
Ndoggct
- Aug 25, 2018
- Ct
Thank youI have done pilots with what you are doing and I have done pilots with Snowtrackers. The pilots with Snowtrackers are night and day difference. The Snowtrackers are what make the sidewinder into what it should be. I was reluctant of trying them years ago. I put pilots on my Nytro. It was ok. I then put the snowtrackers on and it became a totally better machine. Good luck with your new setup. It will be better than stock.
Ndoggct
- Aug 25, 2018
- Ct
I honestly don’t not like them or even know much about them but it looks like a lot more going on on the ski that could either catch something or get caught up in crossing etcWhy,what don't you like about trackers?
I’m sure they are great I am just a nervous person
Avenger
- Oct 27, 2018
- Michigan
- 17’ Sidewinder LTX-SE D&D
19' Sidewinder SRX TD
Stud Boy 7.5” Shaper Bars have worked really well for me on the 5.7’s.
Avenger
- Oct 27, 2018
- Michigan
The outers on the 5.7 pilots will most likely need to be drilled out which is super easy. Honestly though the outside bar is not going to make much diffence in the handling, it only protects the outside of the ski. IMOthanks
