pilot skis toe adjustment
justinator
Maine
2023 Arctic Cat Riot 9000
what are you guys running for toe out specs on your pilot skis...........same as stock or something else?? Aldso are you guys trimming the ski doo rubber stopper at all or leaving it as is?? I would think the ski doo stopper would have alot of preload on it but too much maybe?? After I shimmed my stock skis I noticed it a little harder to back up........skidoo pilots back up okay with the skidoo stopper?? I just orderd some 6.9 for my rtx, wanted a little more flotation then the stock skis. Thanks
I trimmed the back of the rubber stopper on My Pilot skis so they are close to level when the sled is jacked up. If you don't trim them the front of the skis are much higher than the rear. I don't know what the effects of leaving the rubber stopper alone but every sled I ever owned would have theskis level when the front is jacked up.
