mace
anyone try these on their rtx? if so how did you mount them? how do they handle?
thanks
ckm
thanks
ckm
jimmie d
Better chefck DOOTALK lots of complaints on Pilots on wear.
Jim
Jim
I had them good on trail SUCKED off.
dblacks
Don't waste your time with the pilots unless you get them very very cheap. for the same money you can get some c&a's on ebay.
I've got them on my RTX. They are a big improvement on the trail, but
are too loose in the ditches and off trail.
Mine just sunk off trail bad!! LOOK OUT BELOW!!! TO THE BOTTOM I GO!!
slednut
Fella's,
I have 1500 miles on my pilots skiis thus far, this improvement has been nothing but spectacular for trail use, the sled will now actually rail without added heavy steer. To date i've seen no unusual wear issues but again I only have about 1500 miles on them..at the end of the year I could provide a more accurate wear report. These have totally changed (for the better) the handling characteristics on the trail and would reccomend them for sure. Off trail I have no idea how they handle..they bolt on with no additional hardware requirements, 2 bushing's are provided, I put 1 bushing thru the hole from the inside of the ski leaving the collar on the inside of the ski, and the other bushing (outside hole) in from the outside leaving the collar on the outside of the ski..effectively giving you a 1/4in wider ski stance. 2cents
rubber side down,
Slednut
rubber side down,
Slednut
- 20K
