Black RX-1
Has anyone installed the wide frontend kit in their RX-1 yet if so how does it work does it really help the handling. I would think this would do wonders in helping to keep the ski's on the ground through the corners since this would take the ski stance from 42" to 45" any help on this would be appreciated.
deshkae
Nice upgrade, spendy, but if you are just wanting to keep skis on the ground try the straight rate springs and the 12 mm sway bar and longer links. Also pull up your limiter straps about 1/2 inch.
GUKROKIT
Pioneer wide front kit
I ordered this kit in september still waiting for it! You might want to see how much longer it will be or try someone else's arms.I know maximum and mountain performance are selling the 45in arms also! :roll:
I am most likely getting this Front End from Maxx Perf this year for a test review....I will post my findings.
welterracer
How much wider is it and what does it cost
If anyone is planning on selling stock parts to replace with different/better, MAKE SURE the stuff you want is avilable first... :evil:
Black RX-1
3 inches wider includes stright rate springs 12mm sway bar approx. $525.00
Buckeye
- Lakes Region, NH
Pioneer Wide Front Kit
Here is a link. I am interested in this kit, but without the springs.
http://www.pioneermotorsport.com/pp_index.htm
