William Quirk
- Jan 30, 2019
- Newfoundland
- 2006 apex er
Hey I was riding my 2006 apex er I went to pass someone and my skidoo died for a sec I let off the throttle and it started idling Again fine I touched the throttle again it shut off i started it again and touched the throttle it shut off again and did this two more times till it stoped now it will just crank over and over I found a chewed up speed sensor so I replaced the sensor and it is still showing er-1 on the cluster and will just crank over i went through my wiring harness everything looks fine to me but I’m wondering if I fried the ecu when I chewed the speed sensor any help would be greatly appreciated thank you
