Yes tried a different relay with no luck. The fuel pump is actually working when it stops clicking and the pump cuts in. Sled actually started once then stopped once it started clicking again?
Use the dielectric grease sparingly. I was a believer of packing connections with the stuff until I witnessed it be the cause of a poor connection(positive starter cable to the starter). After wiping the connection clean and using just enough to leave a thin layer on the terminals, the problem was solved.
