William Quirk
- Jan 30, 2019
- Newfoundland
- 2006 apex er
Hey I was riding my 2006 apex er I went to pass someone and my skidoo died for a sec I let off the throttle and it started idling Again fine I touched the throttle again it shut off i started it again and touched the throttle it shut off again and did this two more times till it stoped now it will just crank over and over I found a chewed up speed sensor so I replaced the sensor and it is still showing er-1 on the cluster and will just crank over i went through my wiring harness everything looks fine to me but I’m wondering if I fried the ecu when I chewed the speed sensor any help would be greatly appreciated thank you
To chew up the speedo sensor and gear you must have a bearing issue on that side of you jackshaft. I would correct the bearing issue first and work from there.
William Quirk
- Jan 30, 2019
- Newfoundland
- 2006 apex er
I’ve already fixed the bearing when I did the sensor because that’s what chewed it upTo chew up the speedo sensor and gear you must have a bearing issue on that side of you jackshaft. I would correct the bearing issue first and work from there.
dmaxx
- Apr 5, 2006
- sw Michigan
- 2014 Apex XTX, 2012 Apex SE, 2000 Vmax 700, 2000 AC Z-370, fast
- White Pigeon, MI
I ended up buying a new speedo cluster with my er-1 problem. That fixed it. Had tried everything else.
William Quirk
- Jan 30, 2019
- Newfoundland
- 2006 apex er
I bought a ecu on Thursday plunged it in and she fired up after I took the wiring harness out the night before and did a continuity test on each individual wire in the harness and found no problemsI ended up buying a new speedo cluster with my er-1 problem. That fixed it. Had tried everything else.
