Please help me find a part #
RTX
massachusetts / maine
2014 viper rtx
2006 apex rtx
2006 rtx
I blew a belt and it bent the belt guard and broke the aluminum guard mount. I need to replace the mounting bracket'
the mount attaches to the plastic body panel with 2 pop rivets and is L shaped with 2 prongs/fingers to slide the belt guard into.
I need this part #
Also the belt somehow knocked the retaining clip off of one of my quarter turn panel fasteners. I need this # also
I looked online and could not find either part listed in the microfiche.
I found the plastic washers that fit on the quarter turn fasteners but could not come up with the part # for the little retaining ring that keeps the fastener from falling out when unscrewed.
Any help would be appreciated
The item to hold the fastener on is a Spring Plate part # 4XV-2177L-01-00
The Guard Fitting Bracket part # is 8FP-21972-00-00.
The Washer part # is 2TK-21757-00-00.
The part that holds the fastener on when unscrewed is the same washer as on the one that goes in between the fastener and the panel. The Spring Plate is the part that the fastener goes into to keep the panel on.
Steve
