plugs/coils
theewarrior
Canada, Cape Breton
I installed cr10ek plugs and my coils don't seen clip on to the plugs anymore,and the rubber on the top is lose so now when I drive it a little while the coils come up out off the engine. one thing I did notice is that the threads on the new plugs seen a bit smaller them the the cr9s could this be?
Weird. Mine weren't any smaller. Reach inside the caps with a pick and see if you can reform the wire clips a little.
Get the coils pressed on firmly as possible and turn them sideways at a 45 deg. They should lock on, worked for me and don't pop off anymore even on the biggest bumps.
i had this problem , i took the plugs out and very very easy ,i bent over the tops in the plugs ,only a bit and use die electric gease on the tops where the rubber meets the cover ,they arc bad there ,and they fit tight ...
