I have an 06 attak is the 23 tooth top gear the correct swap for this sled? Most the guys around here drag race 600 or 700 feet. Also I want to change the plugs but cant find them are they inside the head cover? Any advice I can get from you guys would be greatly appreciated. Thanks!
23-38 is stock that's what most guys prefer for all around performance.If you have traction like ice picks or chisels and you guys run 600-700 ft i would recommend gearing down but if your racing on snow keep your 23-38 in.As far as the plugs yes they are under the caps.
