Please post your Viper model and whether the spindle is against the inside or outside of your ski ( and your ski stance - 42" or 43") Seems that the sleds are being assembled both ways and wanted to do a pole as to which location you have on your Viper.
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
15 S_TX_DX Outside, corrected as soon as I noticed.
So your came from the dealer with the narrower stance and you changed to the wider stance (spindle against inside of ski ?)
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
both 2014 viper rtx se and 2014 zr 7000 limited spindles are on the inside (wider stance)
SaskAttack
- Jan 4, 2006
- Corning,SK.
Yes, wider is better where I am. And how I drive!
Went to narrow stance. Made zero difference.
rebmo
- Mar 8, 2014
- Rural SE Wisconsin
- 2015 Yamaha RTX-DX blk
2015 Arctic Cat XF 9000 Green (Turbo)
My 2015 R-TX-DX came with spindles on outside 42"stance, moved to inside 43" stance last weekend. Won't know if there's any improvement until it snows again round here. Looking for any increase in stability, 1 " can't hurt. I went by the dealer a couple weeks back and the 2 Vipers on the showroom floor were set at 42" stance.
sk-rx1
I believe the 2015 Assembly instructions say to set the spacers for the narrow setup. This is because some areas require a max width of 48in. The 2014 instructions say to set the spacers as desired but to keep in mind that some areas limit overall width.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I was told the same thing by my dealer. They needed a way to make the ski's conform to the 48" max trail width that some American jurisdictions. This allows them to do that but allow others to be wider if required.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Mines centered. '14 XTX
northof50
- Dec 30, 2013
- Northern ,mb
- 14 viper LTX Deluxe
14 LTX mine came with spindle on the outside. I moved them to the inside. I noticed no difference.
TJ-R
- Jan 28, 2013
- 14 Viper XTX
2014 XTX, new with wide stance. change to narrow. don't see much of a differance in the tight twisties,might be a little easier to lay over in the pow.
They cant be centered unless you made your own spacers. either the factory spacer is on the inside or outside of the steering knuckle.Mines centered. '14 XTX
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
I have 2- 2015 rtx- dx vipers, both came set up in the narrower position. I changed them to the wider stance.
tapex_07
- Feb 15, 2009
Yamadog, I'll check when I get home.
- 6K
