Michael Jardine
- Mar 10, 2019
- New brunswick
- 2-2011 yamaha apex se
Hey guys when I hit he throttle you can hear a clunking in the chain case. Any ideas, the chain is tight as per owners manual specs
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
You sure its not the jackshaft or driveshaft bearings? Chaincase will typically always clunk if there is a problem not just under heavy load.
does the clunk happen when you come onto the gas hard after a hard decel or brake application?
if it does, that is just the play in the reverse built into the chaincase.
