Need for Speed 2
Wow guys Powder Lites have desighned and built one heck of a kit. This is my second attempt at this post so bear with me. the Nytro just flat out pulls. Very easy on fuel and the noise or should I say lack of it is a nice bonus also. The kit was very simple to install and was actually a joy compared to a recent kit I installed on my Apex. As far as things fitting and functioning it is a work of art. The key thing I feel Powder Lites have done is the simplicity of the kit. I rode all weekend with no adjustments to anything . The fuel controller was spot with afs dead on. As this kit gets on the market and tested guys will be happy. Great work Powder Lites
adirondac blue
Any pics of install. Did you do the shim and if so, what octane at what boost. I have heard of guys running 15 lbs on pl kit.
WesG
Couple of Questions.
What fuel controller does the kit use??? Head shim??? What boost and fuel were you using? Any changes the stock Ignition timing? Boost controller or wastegate only? Air intake ice up at all? Any pics
Wes
PS
Hope this one stays on track!
Wes
PS
Need for Speed 2
Sorry guys no pics, No shim just running low boost at present on pump fuel I will be doing cams and shim as per Powder Lites instructions. as for the fuel controller it si the same one we have been using on other kits but it is working. There is a bright spot on the horizon for us with contrllers that is all I can say at present. Call Dave atPowder Lites he can fill people in on some very interesting data that will change the boost game alot. Hope this helps.
