SledFreak
- Feb 7, 2005
- Ontario. Canada
Will it be open right now, if I am currently plugged into the PCIII with the ignition module? If I look, will be open?Srxspec said:There should be a white female plug-in off of the Ignition Module.
Iceman57
SF, when I originally looked at mine I only saw one connector. After I read Allen’s post I whet back and looked more thoroughly. I just returned from inspecting the hook-up and found the other connector that was hidden behind some other wires; my connector also has a black cap in the end of the connector. I am understanding from Allens description that the white connector that has nothing connected to it that is coming off the ignition module harness is where you would plug the LCD into.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Alright all is good and I re-cailbrated my TPS and installed my LCD screen. Works very cool. I have 10 maps loaded so far... Wish I had a Wide Band.... Thanks to everyone..
- 6K
