thunderbolt
Has anybody used this flash with thunder products big venom clutch kit , if so what is your thoughts and what settings did you use on your clutch arms for weight
krm
- Apr 22, 2016
- ny
If you had the kit in a stk one ,add 2gms more to the tip of each ramp
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
pm shagnos or nos pro
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
A bunch of people have/do. Hopefully NOS-Pro or Shagman will chime in on this thread - they're the resident experts.
There's a bunch of good info in this thread https://ty4stroke.com/threads/aftermarket-clutch-weight-testing-from-this-weekend.145153/
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
I’m running max pump on asphalt and they work great I would call lonn from thunderproducts he can help you out it should be a similar setup to evo stage 4. Lonn would be happy to help.Has anybody used this flash with thunder products big venom clutch kit , if so what is your thoughts and what settings did you use on your clutch arms for weight
Bigbluemachine
- Apr 20, 2006
- NY
- 2017 Sidewinder RTX LE
2011 Apex ER
I'm going try a hybrid of sorts based on much of the data gleaned from this site. Power Trail with TP springs and Dalton weights set at 74gms per recommendation. I am sure I'll have to fine tune from there but it will be a good base to start from based on my weight etc. I'll report back upon 1st trip out.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
we might want to compare notes..
I ran it late last year and it worked really well with my Stage 3 Evo.. didnt change it much for stage 4.
TPI Primary Spring
Heel: 3/4 Set Screw
Mid: 3/8 Steel Bolt
Tip: 7/16 Steel Bolt + Thick Washer
Secondary was stock spring at 6-1
1/16 washers under helix
61mm offset from back edge of primary to front edge of secondary.
This was right from Shag
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
TPI Primary Spring
Heel: 3/4 Set Screw
Mid: 3/8 Steel Bolt
Cool...what is the evo stage 3 rated at? and what was the/your base weight on the HH the 58 or 63?
I am going to run this same set up in TDs Kit. The weight says 5.17 but I believe they are 58g. Evo Stage 3 is 51 hp over stock , stage 4 is 58hp.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
If they are the Dalton 70 QAY they are 70gms with slugs up to 77. I am going to start at 74 and go (+)(-) from there based on PT, springs and my gear-less weight at 275. For normal or light guys I think i would start empty.
He was asking about the Heavy Hitters from TPI
thunderbolt
so far good answers from all , will be following Mr.Sled as he is going to use thunder products in a test this year with Ben's stuff aswell
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
sure thingwe might want to compare notes..
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
WE will be testing the TP line up very soon. When we can get snow I'll be able to give baseline numbers. There guys on this board who have run the TP stuff on their asphalt sleds on TD max 17 this summer.
Would give an idea on weight.
