attakred06
2 attak same year same color different mileage at same place in facts they were side by side the gaz the only diffe. mine with 87 would not start after many try and boosting the 91 start right up with no other help... 30miles in the wood it worth the money belive me
SharkAttak
attakred06 said:2 attak same year same color different mileage at same place in facts they were side by side the gaz the only diffe. mine with 87 would not start after many try and boosting the 91 start right up with no other help... 30miles in the wood it worth the money belive me![]()
what would 91 have to do with 87, there must be something else wrong, the only difference is that 87 burns slower than 91, that should have nothing to do with starting
Bullitt GT 07
87 All the way. Another great reason to have a Yamaha 4 stroke!!!! Bullitt GT
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
87 octane burn's faster than higher octane and if any thing 87 will start better because it will egnite easier although i doubt you would notice any differance from 87 to 91. Race sled's with 116 will not start when it gets cold with out help. You never want to run more octane than you have compression to burn, It will make less power and these stock sled's were setup for 87. This has been beat to death, It is a nobrainer. 87=more power and cheaper in these stock motor's.
Dany Pro
Dany Pro said:But with a 2 deg. keyway, 91 octane is the good choice???
Which timing need 91 octane?
attakred06
hi dany pro where are you from in mauricie??? 1 thing i know that it is running better since i change fuel...
Starry Knight
I run 87 mostly, but have run premium in it when the line for 87 was too long at the pump. Never noticed a bit of difference between the two except for price.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
My friend & I with same sleds tested this argument for a solid week in Maine last year. We saw no performance, starting or gas mileage differences. 87 was always 40 to 60 cents cheaper. Another friend who owns a gas station says he refills 87 tank every 4 to 5 days & higher octanes every 10 to 12 days. So no brainer here. If the sleds are modified it's a different conversation all together. Just my 2 cents; or in this case about 50 cents....to me...
Daranello
Suspended
What about 91 for break in since it runs cooler??
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Starry Knight said:I run 87 mostly, but have run premium in it when the line for 87 was too long at the pump. Never noticed a bit of difference between the two except for price.
hey neighbor ! p.m. me sometime and we can b.s.
XDooMan
What does the Manufacturers decal say on the side of your tunnel?
flambo
My sled says 91 octane, it's an 06 Apex. My dealer tells me to disregard the 91 instructions, use 87.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Running higher Octane, then the recommeded by the OEM on a stock sled will actually make you lose power.
rotheno
- Feb 11, 2009
High Octane fuel burns hotter
High octane fuel burns hotter not cooler. Higher compression engines require higher octane to prevent pre-ignition. Low compression engines do not gain any performance from high octane fuel and only burn hotter.
Daranello said:What about 91 for break in since it runs cooler??
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I disagree rotheno, I seem to remember High Octane burning cooler.
