bluecanuck
Two questions:
Can I remove the weights with the primary still on the machine?
Any tricks to getting the old rivets out of the weight or just carefully grind the head off and use a punch?
I want 300 rpm or so on the top end to get in the 10200ish sweet spot so I believe I am doing the right thing by going lighter on the outer (tip) rivet. They are stock 4.5 grams in there now and I was going to try 3.6 grams. I also have some 2.4 grams at my disposal.
Thanks in advance
Thanks in advance
