The Bismarck
I am looking for a tool to compress the primary clutch and hold it so I can change my primary weights without having to take the clutch cover off. Getting tired of having to get a second set of hands to compress the long heelclicker primary spring! I have a tool that I used on the sx and srx but it doesn't compress the clutch enough. I have been looking on aftermarket sites but haven't found one. I believe I bought the original one from maximum performance. Thanks any help you can provide.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
I got one from Hi-Perforamance Engeering
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I have one that you remove the primary clutch bolt and thread into the primary clutch that moves the sheave in allows you to adjust the weights without removing the cover.
the kitchen
I made mine with a 1/2" threaded rod and a fine thread bolt, I cut the head off from the bolt and welded it to the end of the rod. Remove the center bolt and a deepwell socket that will fit over the crank shaft, put a nut and washer behind it and compress away. 8 bucks for home made tool. If you don't use the socket and put a large washer on the rod and remove the front cover bolts you can decompress and reinstall the red, white or black springs all day long by your self.
