ricer68
- Mar 23, 2016
- Wabash Indiana
- 2007 Yamaha Apex GT
- North East Indiana
Does anyone have any tricks for disassembling a primary clutch? I'm getting a puller tomorrow to remove the clutch from my sled. I'm wanting to get the spiders out so i can inspect everything and clean it up. Is there a way to get the primary apart without the Yamaha tool? I've asked in the clutch forum and didn't get any responses, seems this forum gets more traffic so thought i'd try here.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
you have to have a special tool to unscrew the back fix plate off. if you go to a dealer they can do it fast an charge you a small fee like maybe 25.00 and put back together when you are done.
ricer68
- Mar 23, 2016
- Wabash Indiana
Yeah was hoping to avoid going to dealer if possible. That was the backup plan.you have to have a special tool to unscrew the back fix plate off. if you go to a dealer they can do it fast an charge you a small fee like maybe 25.00 and put back together when you are done.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Need tools to hold both half's, it's left hand threads also.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I cant remember what the tool is called but I have seen a how to on making one at home. someone chime in with the name of the tool and a search can be done to find the thread.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
I cant remember what the tool is called but I have seen a how to on making one at home. someone chime in with the name of the tool and a search can be done to find the thread.[/
Grunt tool.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I believe the only way is with th3 tools to hold the clutch from the back side and the tool to spin off the spider. Sometimes takes a very long bar to break it loose.
Sent from my SM-G930V using Tapatalk
